Once you’ve created a new preset or edited an existing one, you’ll want to save it to the USER PRESETS folder and start building your library of tones. You can also save your own custom preset templates, which is a much faster and easier starting point than creating a tone from scratch every time.
Quick-Saving a Preset
If a preset has already been saved to the USER PRESETS folder, and it’s been edited since, the top panel Save button
Press Save to display the Save screen. Different saving options are available depending on the type of preset selected (Factory, User, or New preset) and the specific target location you select for saving the preset (within the User Preset folder, a setlist, in a currently occupied location, etc.). To follow, we cover all the preset saving scenarios.
Probably the most common case is that you’ve loaded a preset you previously saved within the User Presets folder, and you want to save it within its current location to retain your changes. For a Quick Save, simply press the Save button
Tip: Factory presets are “read-only” and cannot be overwritten, but you can select any preset within the Factory Presets folder and double-tap the Save button
Manually Saving a Preset
Press the Save button
. The Preset Save screen appears (see below).
To rename the preset, tap the large preset name in the header
. A keyboard appears. Enter the name and tap
Choose a setlist and preset location in which to save your preset:
If the preset has already been saved, choosing the same location displays
in the sidebar.
If the preset has not yet been saved, or an empty location is selected, Save is grayed out. In this case, you must choose
instead.
If the location already contains a different preset, the Save button changes to
Tap one of the colored boxes in the sidebar:
To simply save any changes made to the current preset, tap
. This is the same as pressing the Save button
twice (or pressing FS4 [Quick Save] from More footswitch mode).
To overwrite an existing preset, select the preset to be overwritten and tap
. A dialog box appears, warning you that the destination preset will be permanently deleted (along with any of its aliases in other setlists). If you’re okay with this, tap Yes, Overwrite.
To save your preset as a new, unique preset, tap
To save your preset as a template, tap
. See Saving a Template below.
Saving a Template
Once you’ve created a preset that includes blocks, signal flow routing, or other configurations that you’re likely to use for future presets, it’s helpful to save it as a template rather than having to recreate it over and over again.
. The Preset Save screen appears (see above).
In the sidebar, tap Save Template
. The Save Template window appears (see below).
To add a template folder, tap
in the sidebar. A keyboard appears. Enter the name and tap
To save as a new template, tap
To replace an existing template, select the template you wish to replace and tap
. A dialog box appears, warning you that the destination template will be permanently deleted. If you’re okay with this, tap Yes, Overwrite.
