Tap to open the Main Menu. Here you can choose from several common commands or screens, such as creating a new preset, opening the Bypass/Control, Global Settings, Command Center screens, and more.
New Preset: Tap to create a new preset from the Templates list. If you want an empty preset, choose “Empty Preset.” See About Presets for details.
Bypass/Control: Tap this button to enter the Bypass/Control screen to create, learn, and edit block bypass and parameter control assignments for the block’s parameters. Bypass/Control is grayed out when no block is selected. See Bypass and Control Assignments for details.
Command Center: Tap to enter the Command Center, where you can configure Helix Stadium’s numerous controllers (Stomp A or Stomp B switches, expression pedals, trigger inputs, the XY Controller, Instant commands, etc.) to transmit various types of commands to control external devices, software, or even Helix Stadium itself. See Command Center for details.
Downloads: Tap to download and install Stadium device updates.
Note: When Helix Stadium is connected to the Internet and you’re signed in to your Line6.com account, the Main Menu icon appears with a red dot if an update is available. We highly recommend you keep your device updated for the latest and greatest amps, effects, and features.
Global Settings: Tap to enter the Global Settings screen, where you can customize Helix Stadium’s settings and preferences to suit your preferred workflow. See Global Settings for details.
Global EQ:Tap to open the Global EQ screen. Global EQ is applied independently of your presets, post-processing, and is used to compensate for the wide disparity in acoustic environments on tour or when traveling from studio to studio. See Global EQ for details.
Disk Utility/Backup: This menu item is currently disabled.*
*Note: The Disk Utility/Backup menu item is reserved for potential future use. Currently, you can use the Helix Stadium Maintenance screen to perform all microSD card tasks, such as formatting a microSD card, creating and restoring backups, and more.
Wi-Fi, Bluetooth, and Ethernet: Tap the respective item to open its panel and configure the connectivity settings for these features. Please see Wi-Fi, Bluetooth, and Ethernet Connectivity for details.
Rename Device: By default, your device is named “Helix Stadium XL” or “Helix Stadium,” but you can customize it, which may be helpful if more than one Helix Stadium or Stadium XL is on the same network. Tap Rename Device and type in your desired pet name.
Account Login: Tap to sign in to your Line 6 account. You’ll need to sign in for various online features, such as update notifications, installing firmware updates, etc.
Firmware Version: The currently installed Stadium firmware version is listed at the bottom of the sidebar for your reference.
