Clones are stored as files within Helix Stadium’s internal memory. Like IR files, clone files can be selected, auditioned, and managed from their own browser via the Model List, as covered in the sections below.
Selecting Clones
The steps for selecting a clone file for your preset are similar to selecting a Cab IR file via the Model List, as described below.
In the Home > Edit screen of your preset, tap on an empty block location in the signal flow and choose the category type in the Inspector for the desired clone:
For an Amp or Amp+Cab type clone, tap the
Amp category button.*
For a Preamp type clone, tap the
Preamp category button.
For a Distortion type clone, tap the
Distortion category button.
*Tip: When adding an Amp type clone to your preset, you’ll likely want to manually add a Cab block after it within the path. Unlike with Amp models, when the Amp clone type is selected, the Add Cab Block sidebar option is not available (since we can’t magically determine an optimal “matched” Cab model for your Amp clone).
Then tap
Once you’ve selected the clone type, tap in the “<EMPTY>” Clone selector box
at the top of the Inspector to open the clone type’s file browser.
All USER CLONES you’ve imported or created for the selected Clone type are listed alphabetically in the right column.
Any folders you’ve created appear at the top of the right column (see the New Folder below).
Tap any clone file once to load and audition it, while keeping its list open for further browsing. Or, tap a clone file twice to load it and return to the Home - Edit screen. The clone’s parameters appear in the Inspector, which you can adjust while auditioning. See Clone Parameters below.
Tap the top header of the Inspector to return to the Home View. You can now edit, move, and create controller and snapshot assignments for the clone, much like any block.
To clear the clone file from the clone block, tap the small X icon at the right of the Clone Selector box
. The box then appears “<EMPTY>.” An empty clone block applies no processing to the signal.
Tap
to move clones between folders or delete them. See the next section.
Tap
to rename the selected clone file or selected folder.
Tap
to add a subfolder within the current clone type folder, and type in the desired name. Adding folders can be helpful to manage large lists of clones (e.g., Clean, Dirty, Face Melting, etc.) See the following Managing Clones section for moving clones.
Note: A maximum of 2,048 Clone files can be stored on a Helix Stadium device. If you import several hundred Clone files or more in one session, the next time you power on Helix Stadium, it may take a few extra minutes to complete initial indexing for the Clone Library. Subsequent startups will not require this additional indexing time. Remember that you can use the Helix Stadium app to Export Clone files to your computer to store them there, and delete them from Stadium if you’re accumulating too many on the device.
Managing Clone Files
Tap
Select All: “Checks” all clone files in the list.
Deselect All: “Unchecks” all checked clone files in the list.
Move to Folder: Select one or more clones, then click to open the Move to Folder dialog to select a destination folder to move them, as shown below. (Note that a Folder can also be selected to move it with all its contents into another folder.)
Delete: Permanently clears the selected clones and folders from Helix Stadium.† Note that deleting a folder also permanently deletes all Clone files within the folder. There is no Undo for deleting Clone files or folders.
†Note: Deleting a clone file from the Clone Library that is used within any saved preset will result in the preset’s respective Amp/Preamp/Distortion block changing to “unknown”
It’s a great idea to perform a backup before you start deleting your clones—all your user clones are included when Creating a Backup to your microSD card (microSD cards are sold separately). You can also use the Helix Stadium application’s Clones Librarian to export clone files and create an unlimited library on your computer for backup and sharing.
Tip: You can also use the Helix Stadium app’s Librarian View to manage your clones, as well as export and import them to/from your computer.
Clone Parameters
Once a clone file is selected for a Clone block, its parameters are available within the Inspector. All clone types offer the same set of parameters, with all set “flat” as the initial default, as described below.
Tip: These clone parameters are also available for previewing within the clone creation Compare screen. Please see the Compare step on the previous Clones page.
Parameter |
Description |
Pre Gain |
Adjusts the amount of gain fed into the clone. Reduce the level for cleaner tones, or increase to drive the amp/preamp/distortion clone for increased saturation and distortion. |
Low Cut |
A High Pass Filter to reduce the level of all frequencies below the selected cutoff value. |
Low Mid High |
Adjusts the bass, midrange, and treble, respectively. |
High Cut |
A Low Pass Filter to reduce the level of all frequencies above the selected cutoff value. |
Post Gain |
Adjusts the output level. Use this to adjust the clone's overall level without affecting its tone. |
Parameter Panel
Just as with Amp, Cab, and Effect parameters, tap on any Inspector Clone parameter to open its Parameter Panel, where you can use its large slider for adjustment, assign a controller, or enable snapshot control. Please see the Creating and Editing Tones > Parameter Panel section for additional details.
