Flag List
The Flag List Window
The Flag List window shows all the current song’s flags in a list along with select settings. Tap the Flag List button The Flag List Button at the top of the Song View, or press the Lower Knob to open the Flag List.
Song > Flag List
Swipe up/down within the list area to scroll and view all flags. Tap on a flag or turn the Lower Knob to select (highlight) a flag in the list.
Item 01 Start Flag: All songs already include a Start flag for the song's start position. The Start flag’s text in the list displays the song tempo and time signature. Note that all songs also already include an End flag, which sets the song’s end time.
Item 2 Flag Time Position: Each flag’s time position is displayed at its left Bar, Beat. Ticks time display (Bar-Beat.Tick).
Item 3 Selected Flag: Tap on a flag in the list, or turn the Lower Knob, to select (highlight) a flag and choose a command from the right sidebar. When you exit to the main Song screen, the highlighted flag in the Flag List is also selected in the Song screen.
Item 4 Playhead Indicator: The blue line indicates the playhead’s current position in the song to provide a reference for the most recently triggered flag.
Item 5 Sidebar Commands:
  • Manage Flags: Enters the Manage view where you can copy, paste, clear, reorder, and move the time position of selected flags. See the following Managing Flags section.
  • Test Flag: Available for Preset/Snap, Looper, Utility, Ext Amp, MIDI, and Hotkey flag types. Tap Test Flag to immediately trigger the flag and test its configured functions.
  • Rename Flag: For Marker, Looper, Utility, Ext Amp, MIDI, Hotkey, and Time flag types, tap to enter a descriptive name for the flag. Its name will appear in this list window as well as on the main Song screen when the flag is selected.
Tip: If you rename a Marker type flag (tap on the pencil icon Marker Rename Button.png at right of the selected Marker’s name in the Inspector), the custom name also appears on the Song screen’s ruler Marker Name - Ruler.png . This can help you more easily indicate your song parts (Verse, Chorus, Feedback Solo, etc.).
To exit the Flag List, press the Song button Home button or press the Lower Knob.
Managing Flags
  1. From the Flag List window, tap Managing Flags in the sidebar. Checkboxes appear to the left of the flag names (below):
The Manage Flags screen
  1. Check box(es) to select one or more flags for editing. Optionally, tap Select All to check all flags, or Deselect All to clear all checked flags. (Start and End flags cannot be checked.)
Tip: Remember that you can use the Undo or Redo button UndoRedoButtons.png to reverse your most recent edit action.
  • Copy Flags: Copies the checked flags to the clipboard for pasting.
  • Paste Flags: Tap on the flag in the list at the time position where you want to paste; your pasted flag(s) are added below the selected flag at that same time position.
  • Clear Flags: Tap to clear checked flags from the song.
  • Move Flags: Tap to open the Move dialog (below). Turn the Bar (Knob 6), Beat (Knob 7), and Tick (Knob 8) for the desired + or - time position change for the checked flags. Tap MoveFlagsButton.png .
The Move Flags dialog
  1. Tap DoneButton.png to return to the Flag List.
