Helix Stadium Native
v1.4 v1.3
v1.4 v1.3 English
Preset Clips and Preset Info
The Preset Clip and Preset Info panels are accessed via the Preset Controls at the top of the plugin window. These features provide helpful audio clips for preset auditioning and notes entry for relevant preset information.
Preset Clips
Click the toolbar’s Preset Clip button Preset Clip Button to open the Preset Clip panel. Every Helix Stadium Native FACTORY preset includes a unique dry guitar or bass riff so you can hear it in context; also known as the “Ohhh, I’ve been chugging with 7-string EMGs through a country preset designed for a single coil Tele. That’s why I thought this preset sucked” feature. Clips can also help you dial in presets without constantly switching between playing and tweaking.
Important! Be sure to reduce the volume on your DAW monitoring system or headphones before entering the Preset Clip view, and gradually increase it as needed.
  1. Load a factory preset and click the toolbar’s Preset Clip button Preset Clip Button . The Preset Clip panel appears, showing the clip’s waveform, transport controls, and parameters, as shown below.
Note: The Helix Stadium Native plugin must be enabled for the Preset Clip Player to be functional (not bypassed via your DAW host track controls).
In some DAW host applications (most typically when using the AU format plugin on a macOS DAW host), it is also necessary to select an audio interface input for the track and enable the track’s Input Monitoring so that the application’s Audio Engine is active. The following alert will be displayed in the player if this is required. Please refer to your DAW host’s documentation for details on enabling these functions, if necessary.
An alert is shown to enable the track’s Input Monitoring
If you perform a Save Preset As of a Factory Preset, its preset clip is no longer available on the new User Preset.
  1. Click the transport buttons to control playback.
Tip: Click at any desired time position on the clip waveform to jump the play cursor to that location.
  • Play Pause button Play/Pause: Click to toggle the clip playback between Play and Paused.
  • Return to Zero Button Return to Zero: Click to return the play cursor to the start of the clip.
  • Back 5 seconds button forward 5 seconds button Back and Forward 5 Seconds: Click to jump playback 5 seconds back or forward.
  1. Configure the Preset Clip Parameter toggle switches for playback behaviors. See the next section.
Preset Clip Parameters
All three of the parameter toggle switches are Off by default.
Description
Auto Start
When On, the clip starts playing automatically upon opening the Preset Clip panel. When Off, the clip can only be played manually by clicking the Preset Clip Play button.
Auto Stop
When On, the clip stops playing when you exit the Preset Clip panel. When Off, the clip continues to play when you exit the Clip panel.
Tip: If you set Auto Stop to Off and Repeat to On, you can close the Preset Clip panel, and the clip will keep looping while you tweak your preset.
Repeat
When On, the clip repeats over and over. When Off, the clip plays once and stops.
Preset Info
Click the toolbar’s Info button the toolbar Preset Info button to display the Preset Info panel for the current preset. Here you can type in info for your own USER presets, like guitar/pickup selection, snapshot assignments, tips/tricks, fajita recipes, etc. This Preset Info is saved with the preset and is also referenced when using the Preset Browser’s Search function.
Tip: All factory presets already include helpful, descriptive notes in their Preset Info screens. Please review the factory presets' Info to get some ideas for how to enter effective details for your own custom presets.
The Preset Info panel - info added
To add or edit info, click in the Preset Info panel and enter your desired text. Be sure to save your preset to retain its Preset Info changes. Note that the Preset Info is not editable for Factory Presets. But you can perform a Save Preset As, and the new User Preset retains the Preset Info and becomes editable.
