The Helix Stadium Application
Important! The Helix Stadium application is supported on Helix Stadium family devices with firmware version 1.1.0 (or later). For preset compatibility between Helix Stadium devices and the Helix Stadium Native plugin, device firmware v1.3.2 (or later) and Helix Stadium application version 1.3.3 (or later) are required. For optimal performance, we highly recommend updating to the latest available firmware and software versions.
In addition to creating, editing, and managing your Stadium presets and asset files, the Helix Stadium app is also an integral part of the Stadium Showcase™ functionality, where you can build songs within the app by adding audio files and uploading songs to your Stadium device to add flags and markers, enabling real-time triggering of Stadium and external devices. The Helix Stadium application and Helix Stadium device firmware v1.2.0 (or later) are required for Showcase functionality. Once you've installed and connected the Helix Stadium application using the instructions on this page, please refer to the Creating Showcase Songs section for details.
The Helix Stadium app can also be used to perform device firmware updates via a USB connection on macOS and Windows computers. Please refer to the Stadium Firmware Updates page for details.
Get The Helix Stadium Application
Download the latest, free Helix Stadium app installer for macOS or Windows from line6.com/software, launch the app installer, and follow its on-screen instructions to complete the installation.
Minimum System Requirements
The Helix Stadium application can be used on macOS and Windows computers with the following minimum system requirements. Later operating system and specifications are recommended.
  • Operating System:
    • macOS v14, Sonoma, 64-bit (Intel® and Apple Silicon processor types are supported)
    • Windows® 11 64-bit
  • CPU: Dual-Core 2.0GHz processor
  • Memory: 8 GB
  • Storage: 8 GB (to allow for firmware updates via the app)
  • Wi-Fi or Ethernet for connectivity to Helix Stadium hardware
  • Line 6 Helix Stadium ASIO® and WinUSB drivers (Windows only—no driver installation necessary for macOS)
    • Note that these drivers are installed by default with the Helix Stadium application v1.2 and later on Windows. A stand-alone Helix Stadium ASIO/WinUSB driver installer is also available at line6.com/software.
  • USB 2 connectivity (for optional USB firmware updating of Helix Stadium hardware)
Connect to your Stadium Device
To use the Helix Stadium application, you’ll need to connect to your Stadium device to wirelessly “sync” its content for real-time preset loading, editing, and import/export of asset files. The connection between the app and device is established when both are connected to your local Wi-Fi network. When Helix Stadium is not connected, the Helix Stadium app displays the Disconnected splash screen.
The “Disconnected” splash screen
The Device Connection button on the app toolbar also displays the current status, as either not connected Connection Options button - Not Connected indicator or connected the Stadium XL Wi-Fi Connected indicator . Please see the following steps to configure your Helix Stadium app-to-device connection.
Application and Firmware Update Notification
Upon launch of the Helix Stadium application and your Line 6 account log in (via the app’s The My Account Button button), the app will automatically check online for both the Helix Stadium application and firmware updates. If you are notified that new versions are available, we recommend installing the available update(s).
If prompted to update both the application and firmware, please update the Helix Stadium application first.
Updating the Helix Stadium Application
If prompted, click The OK Button to initiate the Helix Stadium application update. In the App/Device Update screen, be sure to click the App tab to access the details for the available application version, then click The Download Update Button to proceed. Follow the instructions on the additional screens to complete the update.
The Helix Stadium application Update prompt and App/Device Update screen
Updating the Helix Device Firmware
To perform firmware updates using the Helix Stadium app, you must establish a USB connection between your computer and the Stadium device. If a Firmware Update notification appears after the Helix Stadium application connects via USB, it is recommended to proceed with the update. Please refer to the following Device Firmware Update page for USB connection details.
Firmware Update Required notification
Managing the App-To-Device Connection
  1. By default, your Helix Stadium Global Settings > Preferences > Remote Access is set to “Allow,” allowing connections from the Helix Stadium application via any computer. Optionally, you can set Remote Access to “Require PIN” for added security using the following steps.
    • Go to Global Settings > Preferences and set Remote Access to Require PIN.
    • Also in Preferences, tap on the Set PIN button above Knob 5, type in your desired 4-digit PIN code, and tap the Done button .
Setting a PIN
  1. Enable your computer’s Internet connection, and ensure your Stadium device is connected to the same network via Wi-Fi (or Ethernet)—see the Wi-Fi & Ethernet Connections.
  2. Launch the Helix Stadium app, click the The My Account Button button, and log in to your Line 6 account.
  3. Click the the Application Connect button button to open the Connect To Device dialog.*
    • If desired, keep the Auto-connect at Launch switch on (in the right position) Auto-connect Switch.png , and the app will attempt to connect automatically for future launches.
  4. Click the Connect button Connect Button.png at the right of your Available - network connected Network Available indicator.png Stadium device (see below).
    • If you configured your Stadium’s Remote Access for “Require PIN” in Step 1, enter your 4-digit PIN when prompted and tap Confirm button.png , as shown below.
*Note: Alternatively, on app launch, you can click the Auto-Connect button.png button to skip the Connect to Device dialog and establish the app-to-device connection automatically. If you’ve configured your Stadium device’s Remote Access for “Require PIN,” you’ll be prompted to enter the PIN.
If you encounter problems connecting the Helix Stadium app to your device with these steps, please use the Manual IP Address option below.
Connecting to a Helix Stadium device using a security PIN
  1. Once connected, the app’s toolbar button indicates the connection the Stadium XL Wi-Fi Connected indicator , and the app automatically syncs with Stadium. You can now start using the Helix Stadium app for real-time remote editing and importing/exporting asset files.
Connecting Using Helix Stadium’s Manual IP Address
Some Wi-Fi router configurations may prevent the app from connecting to your Stadium device when using the preceding steps. If you encounter this issue, please use the following steps to manually enter your device’s IP address for connection.
Click to expand... Steps for Manual IP Address configuration.
  1. On your Stadium device, go to the Main Menu > Wi-Fi Settings dialog, and note the IP address displayed there. This IP number is specific to your Stadium device's network connection.
Your Stadium’s IP address appears in the Wi-Fi settings
  1. Launch the Helix Stadium app and click the the Application Connect button button to launch the Connect To Device dialog.
  2. Enter your IP address in the Manual IP Address field and click Add Button.png . When you see your IP Address appear as “Available,” click its Connect Button.png button.
Connecting manually using your IP address
  1. The Helix Stadium app should then connect to your Stadium device.
  2. Note that the Auto-Connect feature is not supported for future connections using the Manual IP Address method. Repeat step 1 above, and your IP address should be remembered and appear in the Manual IP Address field, making it easy to complete step 2.
Main Application Window
The Helix Stadium Application - Main Window
Item 1 Device Connection Indicator & Options The Connection Options button - Connected : Indicates the current app-to-device connection and provides connectivity options.
Item 2 View Selectors The Toolbar view selectors. : Selects the main Views displayed in the app. Please see the individual sections on this page for overviews of each: Home, Librarian, Command Center, and Global EQ Views. For details about the New Song screen Toolbar New Song Screen button.png , please refer to the Songs View > Creating a New Song in the Stadium App section.
Item 3 My Account and Help My Account, Help, and toolbar buttons : The toolbar buttons at the right provide access to the following:
  • My Account: Click to Log In, Log Out, and Manage your Line 6 account.
  • Help: Click to access the About Helix Stadium & Legal Info for app version, copyright, and accreditation details. You’ll also find a link for Helix Stadium Online Support, which will direct you to this online Owner’s Manual.
Item 4 Preset Librarian Panel: A compact version of the Preset Librarian is displayed on the left of the Home View for easy searching and loading of your presets. Click and drag the panel’s right vertical divider to resize its width as desired, or click Preset Panel Hide button.png to hide it.
The Home View
This main application window displays the current preset’s signal flow, where you can create and edit your presets, much like within the Stadium device's Home - Edit View screen. To the left of the app’s Home View, you can also access the Preset List to select a Setlist and load a preset directly into the Home View, as well as several other preset functions. Click the Manage button Manage Button.png to open the Preset Librarian View for additional Setlist and Preset management functions.
Creating New Presets
Choose a Preset Template to begin building your own custom tone. Select the Empty Preset template to start from scratch, or choose one of the other provided templates for a specific signal routing or input configuration.
  1. From the Home View - Menu button Menu Button.png , select New Preset and choose the desired Preset Template.
Tip: You can also create your own custom Preset Templates. Please see Saving Your Presets below.
Select New Preset from the menu, choose the desired template, and click NewPresetTemplateButton.png .
A new, unsaved preset is created within the User Presets folder from the selected template.
  1. Add and edit blocks as desired to build your preset, then be sure to save the preset The Preset Save Button.png to retain it in your library.
Tip: Use the Templates Librarian to manage your Preset Templates.
Editing Your Tones
The Helix Stadium app’s Home View screen is functionally very similar to your Stadium device's Home > Edit screen. You can perform the following tasks in the app and hear your edit results in real-time.
Add blocks: Click on an empty location on any path in the app’s Home View and select the desired model from the Model List at the bottom left of the screen.
Edit block settings: Click on any block in the app’s path to access its parameters in the Inspector panel - Edit Panel at the bottom right of the screen for editing. Also, see the following Using the Focus View section for more editing options.
  • Sliders or Knobs? Over the years, our customers have been pretty evenly split on their opinions for slider versus knob controls for parameter editing. Rather than weighing in on that debate, we’ve provided both options so you can choose. Use the Slider/Knob selector The Slider-Knob Selector to set your preferred Inspector edit panel mode. 🤓
  • Hold SHIFT + turn the Mouse Wheel or Drag on a Trackpad: When the mouse cursor is directly over a parameter slider, knob, or its numerical value, turning the mouse wheel/dragging on the trackpad adjusts its value.
    • When the mouse cursor is directly over the vertical scrollbar at the right of the Edit Panel, turning the mouse wheel/dragging on the trackpad scrolls the panel contents vertically. (When not holding SHIFT, this scrolls the panel vertically, regardless the mouse pointer position within the Edit Panel.)
  • Hover your mouse cursor over any block in the signal flow to access the Block Bypass and Clear Block buttons that appear above it:
Block Hover Buttons
  • Within the app’s Inspector edit panel, right-click on an individual parameter slider/knob for additional functions, such as Reset, Controller Assignment, and more.
  • Click and drag any block left/right to change its position in a path. Drag a block down from a main path to create a split/parallel path, or drag a block to any other existing path to move it there.
  • Right-click on a block to access its Action Panel to create Bypass, Controller, MIDI, or Snapshot Control assignments, Copy, Paste, Clear, Add to Favorites, and more.
  • Remember to click the Save button Preset Save Button.png to save your preset to your device’s library—see the next section.
For editing, you can optionally tap the Focus View button button within the Inspector to open their Focus View screen for visual editing of the current Amp, Cab, or Effect model.* Much like when using Stadium’s Focus View screen, you can drag the target cursor toward any corner of the screen and hear the current model’s settings morph in real time toward the pre-determined settings for each. The mid-screen setting represents the model’s initial default settings. Please also see Focus View for details.
The application’s Focus View (Matchstick 30 amp selected)
*Note: Some model types offer different controls and functions in their Focus View:
  • Cab modes offer a handy mic position controller.
  • EQ models display a parametric or graphic EQ interface.
  • Dynamics > Compressor models include a Gain Reduction meter.
  • Clones (Amp, Amp+Cab, Preamp, and Distortion clones) display the clone file’s metadata that you optionally entered during its creation. The metadata display is for reference only—the fields are not editable.
Saving Your Presets
Once you’ve edited your preset to your liking, save the preset to retain it in your Stadium’s Preset Library. Please also see the Saving Presets page for additional preset and setlist details.
  • Click the Save button Preset Save Button.png at the top of the Home View to open the Save Preset dialog.
The Save Preset dialog
  • To save your changes to the currently saved preset, click the Save button Save Button.png .
  • To name the preset, type in your desired name in the field at the top of the dialog Preset Name Field.png .
  • To save a unique copy of the preset into a different location, select the desired location in the preset list:
    • If the selected location is empty, click the Save As New button The Save As New Buttton to save a copy there.
    • If the selected location already includes a preset, click the Overwrite button Overwrite button.png to replace the current preset.
    • Note that saving a preset into a Setlist location also automatically saves its original preset file within the User Presets list (since Setlists contain only “aliases” that reference their original User Presets).
  • To save the preset as a Preset Template, click the Save Template button The Save Template button and name and save the Template in the Add Template pop-up dialog.
  • To exit the Save Preset dialog without saving, click the Cancel button Canel Save button.png at the top right of the dialog.
Note: Factory Presets are read-only. Therefore, the Factory Presets folder or list is not selectable within the Preset Save dialog. However, you can use the above “Save as New” steps to save a unique, editable copy of any Factory Preset in the User Presets folder.
Configuring Bypass and Controller Assignments
Within the Helix Stadium application, Bypass and Controller Assignment options are available via right-click Action menus, as described in the following sections. Please also refer to the Stadium device’s Bypass and Control Assignment page for additional details regarding assignment types and behaviors.
Creating and Editing a Block Bypass Assignment
Right-click on the block for which you want to create or edit a Bypass assignment to open its Action menu.
A block's Action Panel
A block’s Action panel - Assign to Block
  • To assign to a Switch, Pedal, or XY controller: Choose Assign to Switch. In the Controller Assign dialog that appears, select the specific switch, pedal, or external controller to which you want to assign the block bypass. To remove an existing Bypass assignment, select “None.”
  • To create a MIDI Bypass assignment for the block: Select Assign MIDI from the block’s Action menu. In the MIDI Assign dialog that appears, choose the desired MIDI Command type and its additional Value or Note options. To remove an existing MIDI Bypass assignment, select “None.”
  • To additionally configure the block so that its Bypass is stored and recalled via Snapshots: By default, the Set the block Action menu’s Snapshot Bypass switch is enabled Snapshot Bypass Switch - enabled . If you want the block’s bypass state to not be stored/recalled with snapshots, disable this switch.
Creating and Editing a Parameter Controller Assignment
Practically any parameter for any block can be assigned to a switch, pedal, XY Controller, external, or MIDI for remote control. Most assigned command parameters also allow control via Snapshots. These options are configured in the app’s Parameter Panel.
  1. Click the block you want to create or edit a Controller assignment for.
  2. Within the lower right Parameter Panel, right-click on the desired knob (or slider, if using the panel’s Slider View) to open its Action menu.
The parameter’s Action menu - Controller Assign options
  • To assign to a Switch, Pedal, or XY controller: Choose Assign Controller. In the Controller Assign dialog that appears, select the specific switch or controller to which you want to assign. To remove an existing parameter assignment, select “None."
  • To create a MIDI Bypass assignment for the parameter: Select Bypass MIDI Control from the block’s Action menu. In the MIDI Assign dialog that appears, choose the desired MIDI Command type and its additional Value or Note options. To remove an existing MIDI parameter control assignment, select “None.”
  • To additionally configure the parameter so that its values are stored and recalled via Snapshots: Set the parameter Action menu’s Snapshot Control switch to its right position to enable it the Parameter Snapshot Control switch - enabled .
Tip: You can custom-name the label and/or recolor the LED for any assigned Stomp footswitch within the Command Center window (see next section). Right-click on the desired Stomp A or B footswitch within the app’s Command Center - Stomp A or Stomp B tab and choose Label/Color.
The Command Center View
This view displays the Command Center window for editing the Command Center options for the current preset. All functions within this window are the same as editing within the Stadium device’s Command Center screen. Please refer to the Command Center page for details.
The Command Center windows (Helix Stadium XL)
Tip: To custom-name the label and/or recolor the LED for any assigned Stomp footswitch, right-click on the desired Stomp A or B footswitch within the app’s Command Center - Stomp A or Stomp B tab and choose Label/Color.
Tip: Note that the EXP 1/EXP 2 Pedal controller in the app’s Command Center includes the purple and turquoise buttons above it (Stadium XL XL Only Icon.png only). You can select the purple button and then select the EXP Pedal controller below it to assign a unique MIDI command for EXP 1. Select the turquoise button and select the EXP Pedal controller to assign a unique MIDI Command for EXP 2. (This EXP 1/EXP 2 switch is not available in the Stadium device’s Command Center screen.)
The app's EXP 1 - EXP 2 buttons
Snapshot Control
For Command Center parameters that support it, you can right-click on a parameter slider and toggle the Snapshot Control switch on/off. Enabling Snapshot Control stores its values with snapshots and sends them on snapshot recall. See the Command Center page for additional info.
The Snapshot Control switch
The Global EQ View
This view displays the Global EQ, providing access to the three Global EQs—one for each Matrix Mixer 1/4”, XLR, and Phones layer. All functions are the same as editing within the Stadium Device’s Global EQ screen. Please refer to the Global EQ page for details.
The Global EQ
