Librarian View
The Librarian window provides access to all Helix Stadium file assets, which include Presets, Cab IRs, Favorites, Preset Templates, and Showcase Songs.
The Librarian View > Preset List
Select a Library in the left column (Presets, Cab IRs, Favorites, Templates, or Songs) to display its contents list. Much like working in the Librarian lists on your Stadium device’s screen, you can fully manage all your files in the app. Additionally, the Librarian’s Import and Export options allow you to copy and move files between your computer and Stadium device. See the following sections for details.
Tip: Type into the Search field SearchPresets.png at the top of the Preset Librarian to easily find the presets you want.
Importing & Exporting Presets and Setlists
Helix Stadium presets and setlists can be exported using the Helix Stadium app to build a virtually unlimited library of Stadium preset (.hsp) and setlist (.hss) files. These presets and setlists can be imported into your Stadium device’s internal memory at any time using either the app’s Home View > Preset Panel or the Preset Librarian. Please also refer to the Presets and Setlists page.
Tip: You can import original Helix/HX/Native Plug-in preset files (.hlx) and setlist files (.hls) to add them to your Stadium preset library following the steps below. Please also see the Importing Presets section for details on preset compatibility.
To Import a Preset: From either the app’s Home View Preset Panel or the Preset Librarian, select an empty preset location and use one of the several Preset Import options, as shown below.
Importing a preset > Preset Panel
Importing a preset > Preset Librarian
Importing a preset > Preset right-click menu
  • Browse to your computer folder where preset files are stored, select one (or multiple presets), and import. Note that if you select a preset location that already contains a preset, the imported preset will permanently overwrite it.
  • Alternatively, access the Import Preset command from the application’s main File menu, or drag preset files directly from your computer and drop them into the desired preset list location within either the Helix Stadium app’s Home View Preset Panel or Preset Librarian.
To Export a Preset: Select any Factory, User, or Setlist preset(s) within either the app’s Home View Preset Panel or the Preset Librarian View list and use one of the several Export Preset options.
Exporting a preset > Preset Panel
Exporting a preset > Preset Librarian
Exporting a preset > Preset right-click menu
  • Browse to the desired computer folder where you’d like to store your Stadium preset files and export them.
  • Alternatively, access the Export Preset command from the application’s main File menu, or drag preset files directly from any preset list location within either the Helix Stadium app’s Home View Preset Panel and drop them into a computer folder to export them.
Managing Presets
Use the buttons at the top of the Librarian’s Presets panel to Delete presets from the current User Presets folder or Setlist, or to Create a Setlist that includes alias copies of the currently selected presets. (Presets within the Factory Presets folder are read-only—they cannot be deleted, but can be exported to your computer or dragged into other preset folders/setlists to make editable copies of them.)
The Manage Preset buttons
Tip: Click and drag any preset(s) up/down within the Preset panel to reorder the Library list.
Importing & Exporting Setlists
To Import a Setlist: Use one of the Setlist Import options from either the app’s Home View Preset Panel or the Preset Librarian.
Importing a Setlist > Preset Panel
Importing a Setlist > Preset Librarian
  • Browse to the computer folder where Stadium setlist files are stored, select one or more setlist(s), and import them. The imported setlist will be added as the last Setlist.
  • Alternatively, you can access the Import Setlist command from the application’s main File menu.
Note: Since setlists contain only “alias” type presets, an original reference preset file for each imported setlist preset is added into the User Presets folder.
To Export a Setlist: Use one of the several Export Setlist options from either the app’s Home View Preset Panel or the Preset Librarian.
Exporting a Setlist > Preset Panel
Exporting a Setlist > Preset Librarian
Exporting a Setlist > Preset Librarian right-click menu
  • Alternatively, access the Export Setlist command from the application’s main File menu.
  • Browse to the desired computer folder where you’d like to store your Stadium setlist files and export them.
Managing Setlists
Use the buttons at the top of the Preset Librarian’s Setlist panel to create a New setlist or Delete or Duplicate the currently selected setlist(s).
Tip: Click and drag any setlist(s) up/down within the Setlist panel to reorder the list.
The Manage Setlist buttons
Importing & Exporting IR Files
Helix Stadium devices can utilize third-party Impulse Response .wav files within one or both tab locations within a Cab block, providing endless possibilities for speaker emulation. Please refer to the Cab IR section for details on using IRs. Many vendors now offer expertly captured IRs of practically any speaker and mic combination. Once you’ve purchased and saved IR .wav files to your macOS or Windows® computer, launch the Helix Stadium application and import your desired IRs into your Stadium device’s IR library.
Note: If you import several hundred IR files, the next time you power on your Helix Stadium device, it may take a few extra minutes to complete a necessary indexing process for the IR Library. Future startups of your device will not require this additional indexing time.
Importing IR Files
Within the Librarian View, click the Cab IRs button Edit_CabIRLibButton.png within the left column to open the Cab IRs librarian. The Cab IRs librarian is initially empty.
Note: Import of mono or stereo IR .wav files of any sample rate and bit depth is supported. IRs are automatically converted and processed within Helix Stadium as 48kHz, 32-bit float, mono.
  1. Click on the Import button Edit_UploadButton.png , browse to the folder on your computer where your IR .wav files are stored, select the desired IRs, and import them.
    • Alternatively, you can drag IR .wav files from your computer folder and drop them directly into the Cab IR librarian to import them.
  2. When the import is complete, you’ll see all IRs appear in the librarian’s right pane. These IRs are then available for any preset’s Cab blocks.
The Cab IRs Librarian - initially empty
The Cab IRs Librarian - IRs imported
  1. To Use Your Imported IRs: Add a Cab block within your preset, select either of the tabs within Cab’s Inspector, select the Cab IR category, and your list of imported IRs is available for selection. You can add up to two IRs within a Cab block. Please refer to the Cab IR page for additional details.
Exporting IR Files
  • To Export IRs: Select the desired IR file(s) within the Cab IRs Librarian right pane, click the Export button, browse to the desired folder on your computer, and save.
Exporting Cab IRs
Managing IRs
Use the buttons at the top of the Cab IR Librarian to Delete* or Rename the selected IRs, or to create a New Folder for managing your library of IR files. Please also refer to the Cab IR File List section for additional details.
*Note: Deleting an IR file from the IR Library that is used within any saved preset will result in the preset’s Cab block changing to “UNRESOLVED,” with no IR loaded in the respective tab.
  • Note that you can select the desired IRs in the list, then click New Folder to automatically move all selected IRs into the newly created folder in a single step.
    • Folders always appear at the top of the Cab IR list. Drag IRs between the IR list and your folders to move and arrange them as desired.
    • Click on a folder to show its contents on the right.
The Manage Cab IRs buttons
The Cab IR List > IR Folder selected
Importing & Exporting Favorites and Preset Templates
The Helix Stadium app’s Librarian View also offers import and export for your Favorites and Preset Templates. This allows you to back up these files on your computer and restore them individually as desired.
Within the Librarian View, click Favorites Edit_FavoritesButton.png or Templates Edit_TemplatesButton.png within the left column to open the desired Librarian window. The Librarian will show all Favorites or Preset Templates stored within the connected Helix Stadium’s internal memory. Please also refer to the Favorites and Saving Preset Templates sections for details.
Importing Favorites or Preset Templates
Click on the Librarian’s Import button, browse to the folder on your computer where your Favorite or Template files are stored, and select and import the desired file(s). Alternatively, you can drag Favorite or Template files from your computer folder and drop them directly into the app’s respective Librarian to import them.
Favorites Librarian - Importing Favorites
Tip: You can import either Stadium Favorite (.hls) or original Helix Favorite (.fav) files.
Templates Librarian - Importing Templates
Tip: A set of Preset Templates is already included to get you started.
Exporting Favorites or Template Files
Select the desired file(s) within the Librarian right pane, click the Export button, browse to the desired folder on your computer, and save. Alternatively, you can drag Favorite or Preset Template files to a computer folder to export them.
Favorites Librarian - Exporting Favorites
Templates Librarian - Exporting Templates
Managing Favorites and Templates
Use the buttons at the top of the Favorites or Templates Librarian to Delete or Rename the selected files, or to create a New Folder to manage your Favorites and Templates.
The Manage Favorites buttons (left) and Manage Templates buttons (right)
  • Note that you can select the desired Favorites or Templates from the list, then click New Folder to automatically move all selected files into the created folder in a single step.
    • Drag files between the Librarian list and your folders to move and arrange them as desired.
Managing Songs and Playlists
The Songs Librarian manages all Showcase songs and playlists stored on Helix Stadium. Click the Songs button in the left column to display all current playlists and songs. Click on the SONG LIBRARY folder or an existing playlist to access its list of songs.
Note: Creating a new song is accomplished in the app’s New Song window—see Creating Showcase Songs.
Songs Librarian > SONG LIBRARY list
Managing the Song List
  • To Reorder Songs in the List: Click to select one or multiple songs in the list and drag up/down to the desired position.
  • To Rename a Song: Click twice on a song in the list, type in your custom name, and press Enter/Return.
  • To Add Songs to a New Playlist: Select the desired songs in the list and click the Create Playlist button Create Playlist Button.png at the top of the list. This creates a new playlist in the left pane and adds the selected songs to it.
  • To Add Songs to an Existing Playlist: Select the desired songs in the list and drag them onto the desired playlist in the left pane.
  • To Delete Songs from the SONG LIST or a Playlist: Click to select the songs in the list and click the Delete button Delete Songs button.png at the top of the list:
    • Deleting any SONG LIST song permanently deletes the song from Helix Stadium, including all “alias” versions of the song from playlists.
    • Deleting any playlist song clears the alias song from the current playlist only. The original, referenced song in the SONG LIBRARY and any other playlists' instances of the song remain undeleted.
Managing Playlists
Songs Librarian > Playlists column
Once you create one or more playlists, they appear in the Playlists column of the Song Librarian, as shown above. Click to select a playlist to access its contents in the right column list.
  • To Reorder Playlists: Click to select a playlist and drag it up/down to the desired position.
  • To Rename a Playlist: Click twice on a playlist, type in your custom name, and press Enter/Return.
  • To Create a New Playlist: Click the New button New Playlist Button.png at the top of the Playlist column. This creates a new, empty playlist in the left Playlists column. Optionally, type in a custom name for the playlist and press Enter/Return. You can drag Songs from the SONG LIST folder’s right column list onto a playlist to add alias songs to it.
  • To Duplicate a Playlist: Select the desired playlist in the Playlists column and click the Duplicate button Duplicate Setlist.png . This creates a copy of the selected playlist and all its songs.
  • To Delete a Playlist: Click to select a playlist and click the Delete button Delete Songs button.png at the top of the Playlists column. This deletes the selected playlist and all its “alias” songs. (The original, referenced songs in the SONG LIBRARY remain undeleted.)
