version: "Rev D_v1.3"
language: "en"
# Loopers
Helix Stadium has a few different Loopers: **Deluxe** , **1 Switch** , and **Shuffling Looper**, each of which is available in Mono and Stereo versions. A Looper block can exist anywhere on either Path 1 or Path 2---one Looper block per preset, maximum. The Looper records to Stadium's internal memory, with the following maximum loop recording times.
|       **Looper Model**        | **Maximum Loop Time (Full Speed)** | **Maximum Loop Time (Half Speed)** |
| **Deluxe Looper (Mono)**      | 120 seconds                        | 240 seconds                        |
| **1 Switch Looper (Mono)**    | 120 seconds                        | 240 seconds                        |
| **Shuffling Looper (Mono)**   | 60 seconds                         | n/a                                |
| **Deluxe Looper (Stereo)**    | 60 seconds                         | 120 seconds                        |
| **1 Switch Looper (Stereo)**  | 60 seconds                         | 120 seconds                        |
| **Shuffling Looper (Stereo)** | 30 seconds                         | n/a                                |
**Important!** If you load a different preset while looping, loop playback/recording will stop unless the preset you select next includes the ***same*** type of Looper block (the same Deluxe, 1 Switch, or Shuffling Looper type, and the same Mono or Stereo type), *and* the Looper block exists on the same path in both presets.
Your recorded loop is not saved with the preset and is cleared from memory once you power off your Stadium device.
## Adding a Looper Block
1. **From the Home \> Edit screen, tap an empty area on a path where you want to add the Looper block.** Categories appear in the inspector.
2. **Press \[\>\] (or swipe the category buttons) and tap the Looper category button.** The Model List opens (see below).
3. **Tap the desired item to load it. Alternatively, double-tap the desired item to load it** ***and*** **close the Model List.**
![ModelBrowser_Loopers.png](https://manuals.line6.com/__attachments/a_ead0016a75657e56efa48857f520de1eddd3d7712ca67dc7b00cbb94958f2c34/ModelBrowser_Loopers.png?cb=afc8c8a612f5da12fa9326042e3b10b4)
Note that Looper types are available as Mono or Stereo, selectable in the right sidebar. If stereo loop playback is not required, or if you'll be placing mono blocks after the Looper in your signal flow, it is best to choose a mono Looper. Once the Looper block is added, a Stomp mode footswitch assignment is created to access the Looper (also see [**Footswitch Modes**](https://manuals.line6.com/en/helix-stadium/live/top-panel-and-footswitches.md)).
Please take a look at the section below for details on each Looper model type.
**Tips:**
* Use the**Command Center \>** [**Looper Commands**](https://manuals.line6.com/en/helix-stadium/live/command-center.md)to customize your Stomp Mode footswitches with multiple Looper functions for a Looper block.
* Use the [**Song View \>** **Flags**](https://manuals.line6.com/en/helix-stadium/live/flags.md)**\> Looper flags** to automate your preset's Looper block functions within your Showcase songs.
* Control the Looper remotely via MIDI---see [**MIDI CC**](https://manuals.line6.com/en/helix-stadium/live/midi.md).
## Deluxe Looper
The Deluxe Looper utilizes a dedicated footswitch mode for full-featured control of loop recording and playback functions.
**Tip:** If you import a Helix/HX preset that includes a 6 Switch Looper block, its looper is automatically converted to a Deluxe Looper.
### Deluxe Looper Parameters
![The Inspector showing the Deluxe Looper parameters](https://manuals.line6.com/__attachments/a_8fe21d3b86613dab1d52c262e09e08593e22a1454e8c5ec6376a41906d403683/DeluxeLooper_Inspector.png?cb=2f859aa5774791f32ed6abc965a8298b)
Click to expand the Deluxe Looper parameter descriptions...
| **Parameter** |        **Description**        |
| **Playback**  | Controls the level of looper playback. You may find it helpful to turn this down a bit so your live guitar can be slightly louder.        |
| **Overdub**   | Controls the level of your recorded loop *relatively, over time,* while overdubbing. For example, if Overdub is set to -6.0 dB, each time your loop repeats, its volume will be reduced by that amount, becoming quieter with each overdub pass. |
| **Low Cut**   | Applies a low cut (high pass) filter to loop playback, letting you remove the effected signal below a specified frequency. Filtering your loop can sometimes improve the mix with your live instrument.                                          |
| **High Cut**  | Applies a high cut (low pass) filter to loop playback, letting you remove the effected signal above a specified frequency. Filtering your loop can sometimes improve the mix with your live instrument.                                          |
### Deluxe Looper Footswitch Mode
1. **From Stomp A or Stomp B footswitch mode, press the Deluxe Looper switch.** Deluxe Looper Footswitch mode appears (see below).
If no loop has yet been recorded (or the loop has been cleared), the device's switch LED rings appear dark and its footswitch labels are dimmed. The Speed and Reverse switches can be "pre-engaged" prior to recording your loop if desired.
![10SwLooper_XLSwitches_V1_0.png](https://manuals.line6.com/__attachments/a_8604056c7517e3c8944e7d2067160a40cd9ac39b1af267e201c74522f270f177/10SwLooper_XLSwitches_V1_0.png?cb=fd922d81bea0d53921da2d8b96e803d4)
^**\***^**Note:** On Helix Stadium XL ![Helix Stadium XL only](https://manuals.line6.com/__attachments/a_5f02da009a7d8bf9e370237928e217d097b9f635fed492359ff208b4a116b916/Icon_XL.png?cb=eb82c58bec6c3f8aaf1811bc572e962e) , the Looper footswitch labels appear on the scribble strips when the Deluxe Looper block is enabled. On Helix Stadium, Deluxe Looper footswitch labels appear on Home \> Play view (see below).
![HelixStadium_LooperMode.png](https://manuals.line6.com/__attachments/a_8f5f73d5ea7787a1ca2ca0ef5243cf0773433bbf65ab1f90d96ca8b62b0622e9/HelixStadium_LooperMode.png?cb=52a2a530a2adda7ca702675d3f67a2f9)
Click to display the list of Deluxe Looper footswitch functions...
|       **Function**       |        **Description**        |
| **FS1 (Clear)**          | **Press to instantly clear the loop from memory, whether it's currently recording, playing, or stopped.**        |
| **FS2 (Undo/Redo)**      | **Press to undo the most recent overdub pass.** Once the switch is released, the function changes to Redo. **Press again to restore the last cleared overdub pass.** The function changes to Undo again.        |
| **FS3 (Speed)**          | **Press to toggle between Full Speed and Half Speed.** If **Half Speed** is engaged before or during loop recording, pressing FS3 again will double the speed. The speed also affects the pitch of the loop playback. Playing a Half Speed-recorded loop at Full Speed raises its pitch one octave, while playing a Full Speed-recorded loop at Half Speed lowers it one octave.                           |
| **FS4 (Reverse)**        | **Press to toggle loop playback between forward and reverse.**        |
| **FS8 (Record/Overdub)** | **If a loop is not playing, press FS8 to record a new loop.** The switch's LED turns bright red. **If a loop is playing, press FS8 again to overdub.** The switch's LED turns bright orange. Overdubbing records your input signal as a new part, without removing the existing loop. If you remain actively overdubbing, a new, additional Overdub layer is recorded every time the loop playback cycles. |
| **FS9 (Play/Stop)**      | **Press to start loop playback. Press again to stop playback.**        |
| **FS10 (Play x1)**       | **Press to start loop playback.** Playback continues until the end of the loop and automatically stops. **Tip:** Press **FS10** rapidly and repeatedly for a "stuttering" playback effect!        |
### Deluxe Looper - Simple Tutorial
To follow, we've provided a quick example for using the Deluxe Looper to get you up and going on the marvels of Looping. Of course, the number of possibilities for how you combine and utilize all the features is practically endless, but you'll get the idea. For the following steps, we're using all the factory default settings for the Looper parameters.
1. From Stomp A or Stomp B footswitch mode, press the Deluxe Looper switch. On Helix Stadium, press Home until you see Home \> Play view.
2. Count yourself in and press **FS8 (Record)** on the downbeat of a measure to start recording.
3. Record four measures of chords or a riff for a rhythm, then press **FS9 (Play/Stop)** on the downbeat of what would be the fifth measure to stop recording. Your loop automatically exits recording and starts playing.
   * You've now recorded a loop that you can play along with to your heart's content. Adjust the **Playback** parameter (Knob 1) to set the loop playback volume as desired. Go to the next step if you want to overdub some riffs on top of your loop.
4. Press **FS9 (Play/Stop)** to start loop playback. Once you're ready for your big moment, step on **FS8 (Overdub)** as the loop plays to enter Overdub record mode and go wild for a solo for four bars.
   * If you're really feeling fancy, you can keep the overdub running after the first loop cycle and record a second layer for a doubled solo.
5. Press **FS9 (Play/Stop)** at the end of your four bars to exit Overdub, and your loop will keep playing---now featuring both your rhythm and solo parts.
   * Keep repeating the last two steps to add additional overdub layers as desired.
   * If you mess up an overdub, press **FS2 (Undo)** once to delete the most recent overdub while retaining your original loop.
6. To delete the entire recorded loop, press **FS1 (Clear)**.
#### Additional Deluxe Looper Tricks
* Press **FS3 (Half Speed)** and you'll hear the whole thing at half speed.
* Press **FS4 (Forward/Reverse)** and you'll hear everything playing backwards, and still at half speed.
* As the loop plays, press **FS8 (Overdub)** and lay down some more guitar. Press **FS9 (Play/Stop)** to stop overdubbing and play the whole shebang, and then press **FS4 (Forward/Reverse)**. Now the loop is playing forward again, and the last part you recorded is backward in relation to everything else.
* Press **FS3 (Half Speed)** and playback returns to normal speed. You can imagine where a half hour of this kind of thing could get you.
* At any time, press **FS10 (Play 1x)** to play the entire loop once from its start. Or, for fun, you can tap FS10 fast and repeatedly to keep re-triggering it for stuttered playback.
* Remember that looping doesn't need to be limited to guitar parts! Connect a mic and capture vocals or any type of instrument or noise you can think of to add to your loops.
## 1 Switch Looper
The 1 Switch Looper offers simplified Loop recording and playback, all from a single Stomp mode switch.
1. **Add a 1 Switch Looper block to your preset. If not already assigned, assign it to a Stomp mode switch.**
2. **Press the 1 Switch Looper switch.**The LED lights red, indicating the loop is recording.
3. **Press the 1 Switch Looper switch again.**The LED lights green, indicating the loop is playing back.
4. **Press the 1 Switch Looper switch again.**The LED lights amber, indicating the loop is in overdub mode. Subsequent presses of the switch toggle between play and overdub mode.
5. **While the Looper is in play or overdub mode, press and hold the switch for 1 second.**The most recent recording is undone. Holding the switch again will redo the recording.
6. **Quickly double-press the 1 Switch Looper switch.** Playback/recording stops, and the LED appears dim green, indicating a loop is in memory. **Press again to start playback.**
7. **While Looper playback/recording is stopped, press and hold the switch for 1 second.**The most recent recording is deleted, and the LED lights dim white.
**Tip:** Intended to be quick and simple, the 1 Switch Looper offers fewer functions via its single switch than the Deluxe Looper (such as 1/2 Speed, Reverse, etc.). However, all the functions available for the Deluxe Looper can also be accessed by assigning Command Center \> Looper commands to Stomp switches. As long as the current preset includes a Looper block of any type, Looper command switches will control the looper. This effectively lets you create a "custom" layout of Looper switches within Stomp A and/or Stomp B footswitch modes. See [**Command Center - Looper Commands**](https://manuals.line6.com/en/helix-stadium/live/command-center.md).
### 1 Switch Looper Parameters
![The Inspector showing the 1 Switch Looper parameters](https://manuals.line6.com/__attachments/a_a2cf26624eb3fd930d648c9dc57eb776d620dd7433a3edbbf0dd21bd2534cffc/1SwLooperParameters.png?cb=c8057c4799395cd2c6c708c1bdf1f96a)
Click to expand the 1 Switch Looper parameters descriptions...
| **Overdub**   | Controls the level of your recorded loop *relatively, over time* while overdubbing. For example, if Overdub is set to -6.0 dB, each time your loop repeats, its volume will be reduced by that amount, sounding quieter and quieter with each overdub pass. |
| **Low Cut**   | Applies a low cut (high pass) filter to loop playback, letting you remove the looper signal below a specified frequency. Filtering your loop can sometimes improve the mix with your live instrument.                                                       |
| **High Cut**  | Applies a high cut (low pass) filter to loop playback, letting you remove the looper signal above a specified frequency. Filtering your loop can sometimes improve the mix with your live instrument.                                                       |
## Shuffling Looper
The Shuffling Looper is a distinctly different animal from the other Loopers. Part looper, part sampler, part performance instrument­---the Shuffling Looper chops up your recorded loop, randomizes the slices, and gives you control over reordering, octave shifting, reversing, repeating, and more.
Before starting, select the Shuffling Looper block within the Home \> Edit screen and observe and adjust the Looper parameters as desired (see the following table of Shuffling Looper parameter descriptions).
1. **Add a Shuffling Looper block to your preset. If not already assigned, assign it to a Stomp mode switch.**
2. **Turn Knob 1 (Slices) to set the number of slices your loop will be chopped into.**
3. **Press the switch to begin recording.**The LED lights red, indicating the loop is recording.
4. **When done recording your loop, press the switch.**The LED lights green, and the sliced loop sequence starts playing immediately.
5. **During playback, adjust the Shuffling Looper knobs.** See [**Shuffling Looper Parameters**](https://manuals.line6.com/en/helix-stadium/live/looper-block.md#Shuffling-Looper-Parameters) below.
6. Want to change it up? **While the loop is playing, press the switch to randomize its slice sequence.**
7. **Quickly double-press the Looper switch.** Playback/recording stops, and the LED appears dim green, indicating a loop is in memory. **Press again to start playback.**
8. **While the loop is playing or stopped, press and hold the switch.**The recording is deleted, and the LED lights dim white.
**Tip:** Try assigning an expression pedal to the Shuffling Looper parameters for even more creative control!
### Shuffling Looper Parameters
![ShufflingLooper_Parameters.png](https://manuals.line6.com/__attachments/a_4b4fb1fbca8a4b1c633f4e2a058b86008ef88485d04ec818cd5c6a5e9269749c/ShufflingLooper_Parameters.png?cb=459308851667528889a3cfa552e3faed)
Click to display the full list of Shuffling Looper parameters...
| **Parameter**  |        **Notes**        |
| **Slices**     | Changes the number of slices your loop will be chopped into        |
| **SeqLength**  | Determines the number of slices in the sequence. This can be changed even after recording a loop.        |
| **Shuffle**    | Determines the likelihood of slices shuffling/reordering. At 0%, the slices never shuffle; at 100%, they're constantly reshuffling.        |
| **Pitch**      | Determines the likelihood of slices playing back an interval higher or lower, determined by the Interval 1 and Interval 2 parameters.        |
| **Reverse**    | Determines the likelihood of slices playing backward. At 0%, all slices play forward; at 100%, all slices play backward.        |
| **Repeat**     | Determines the likelihood of slices repeating. At 0%, no slices repeat; at 100%, all slices repeat.        |
| **Smoothing**  | Higher values apply smoothing between slices and can give a synth-pad type quality. Lower values maintain transients. Or set it just high enough to avoid pops and clicks.        |
| **Seq Drift**  | Determines the likelihood of the entire sequence changing every time it loops around. When set to 0%, the same sequence repeats forever; when set to 100%, the sequence changes completely every time it loops.                                |
| **Playback**   | Sets the overall level of the playback sequence.        |
| **Interval 1** | Sets the pitch of some slices, the likelihood of which is determined by the Pitch parameter (from an octave down to an octave up). If you want slices to change to a single pitch, set one Interval to that pitch and the other Interval to 0. |
| **Interval 2** | Sets the pitch of some slices, the likelihood of which is determined by the Pitch parameter (from an octave down to an octave up). If you want slices to change to a single pitch, set one Interval to that pitch and the other Interval to 0. |
